Thread Tools
Old 21-02-2015   #1
Bulletproof Saint has donated!
Angry Car won't start :(
Hello Friends,
We are decorating the back bedroom, I was just getting ready to drop the little one off at grandma's before a trip to Wickes. Go to the garage to get the car out, put the key in the ignition and......arut aurt aurut.........no broooommmm! WTF stilo? what happened to you?
So I'm now searching the forums for advice and knowledge, there's certainly no shortage of it here
So far I have
- checked and changed the plugs
- coils seem ok on inspection, no burnt or smelly coils
- Checked the battery (went to charge it and the status reading went straight to ok/charged, although not sure that can be relied upon)
- FES gave a reading of 11.8v when checking the battery.
- Fuel is reaching the plugs so I have ruled out the fuel system
- ran all the actuator tests in FES, the RPM counter throws up alternator fault when run, with ASR and loose connection errors. Dont know if this is a true error, I assume so.
- Tried a different key (both remote fobs)
- had the battery out for a couple of hours
My next steps are to
- check the fuse box and engine earths and make new ones.
- Bagder my mate for him to return my multimeter, can't really progress without this!
Are there any other things that I can quickly rule out?
I'll shorlty upload a video of the noises and warnings.
Thanks all
5dr 1.6 Dynamic, Clarion DUZ388RMP, Yankee Candle Air Freshener!
Bulletproof Saint is offline Reply With Quote Quote
Old 21-02-2015   #2
Re: Car won't start :(
Old 22-02-2015   #3
Quote Originally Posted by Bulletproof Saint View Post
Hello Friends,
So far I have
Thanks all
My first gut reaction is the ECU has died. Very common as it gets very hot over the years. BUT..... best to rule everything else out first as they're expensive to replace.
2002 Stilo 1.6 16v
SGThirkell is offline Reply With Quote Quote
Old 22-02-2015   #4
bri1232 has donated!
Does it have battery cover
what error codes do you get when using multiecuscan
post error codes for engine ecu + abs ecu + body ecu.
bri1232 is offline Reply With Quote Quote
Old 22-02-2015   #5
Engine
U1600 electronic key
U1601 C-CAN LINE ERROR
Old 22-02-2015   #6
Abs
c1520 - can line error
c1521 - engine > abs data line
Old 22-02-2015   #7
Can't read the body codes atm. Have some issues getting FES to work on the CAN system.
Old 22-02-2015   #8
Sounds like Engine ecu failure.
Old 22-02-2015   #9
Thanks for the replies, I'm not looking forward to this repair! It must be said, this car has done me pretty well. Owned since 2008, other than the airbag warning it has never given me any real problems up until now! Lol.
What sort of damage am I looking at for a new engine ecu?
Can they be sourced outside of the stealer..... I mean, dealer network?
Old 23-02-2015   #10
You could try ebay.
Old 23-02-2015   #11
GPz750 has donated!
Scrap yard.
GPz750 is offline Reply With Quote Quote
Old 23-02-2015   #12
Sorry, I thought these Ecus "imprinted" with a unique code to the car? And you can't chop an change them?
Is this different to the body ecu then in that regard?
Old 23-02-2015   #13
GPz750 has donated!
I was thinking its the cars computer that has to be coded to the car.
Old 23-02-2015   #14
GPz750 has donated!
Quote Originally Posted by GPz750 View Post
Wrong
Just had a look at some on ebay and the need codding. Saying that there is a self coding one (New) at 165. Think i would need to be 100% sure this is the problem before spending that. Christ i have had cars cheaper than that
Old 24-02-2015   #15
Romania
If replacing for second hand items, you will need to get the new ECU virginised, of by the ECU with the body computer AND the keys, as a kit, from the same car.
I would not buy the ECU yet, but rather delete the errors, see if they come back on.
then i would do this :
Likes Bulletproof Saint liked this post
aurick86 is offline Reply With Quote Quote
Thread Tools
(T) Car won't start Bannon Punto (Mk1) 13 20-12-2013 22:57
(G) car won't start andy1977 Punto (Mk2/2b) 7 17-02-2013 23:52
(T) Car won't start unless you bump start it? benny279 Punto (Mk2/2b) 11 10-06-2012 18:04
Car won't start. Paulo FIAT Boo Archives 8 03-11-2006 17:06
HELP! Car won't start! Ben B FIAT Boo Archives 16 19-12-2004 20:53
