SLOVAC said:Just had a look... on the 3dr there are only 3 bolts that need to be removed, and the electrical connection needs to be disconnected.
Doesn't look like it will be a big job....
SLOVAC said:Easy enough to get at... there is an access flap that you go through.
activematt said:Good luck if you reckon you can get through that little flap, i ended up just ripping all the interior to the boot in the end cos i got annoyed with trying to get through that flap.
