Thread Tools
Old 10-06-2012   #1
Rallying Crazy guy
nikkiy9 has donated!
Brake Bleeding
is it best to bleed the brake system with the engine running (for full vacuum) or with it off, bearing in mind i've had to remove the ABS Pump etc due to changing the servo
nikkiy9 is offline Reply With Quote Quote
Old 10-06-2012   #2
MarkThompson4 has donated!
Re: Brake Bleeding
I don't think it matters, you can bleed it with the engine off. As you've had the ABS pump off, you should connect FES up so as you can open up the individual ABS valves to properly bleed the system, though this is standard practice anyway.
www.facebook.com/goldtop91
MarkThompson4 is offline Reply With Quote Quote
Old 10-06-2012   #3
Rallying Crazy guy
Re: Brake Bleeding
I would use FES but when I tried to connect my abs to fes it mucked up the body computer, that's why I was asking about running the engine
Old 10-06-2012   #4
Re: Brake Bleeding
Don't think it'll make a difference running the engine, you'll need to open the ABS valves to properly bleed the brakes regardless, don't think you can do that without FES :s
Old 10-06-2012   #5
NobodyBlamesTheHappyGuy!
Morty Mort's Avatar
Trader Rating: 2
Morty Mort has donated!
Norway
Re: Brake Bleeding
It's pretty oldschool. If you get a brake bleed kit (like Gunsons one-man Eezibleed) it's just plug on and bleed each nipple in turn. Don't have to have engine running, or a computer hooked up.
jet blue. eibach pro system. omp bar. gsr in. supersprint out. hella eyes. phoenix gold watts.
member of the 5-door massive attack.
Morty Mort is offline Reply With Quote Quote
Old 11-06-2012   #6
Rallying Crazy guy
Re: Brake Bleeding
Mort, I've got my own home made bleed kit, works a treat too
Old 11-06-2012   #7
Morty Mort's Avatar
Trader Rating: 2
Norway
Re: Brake Bleeding
Quote Originally Posted by nikkiy9 View Post
Great! I was making my own earlier too, but had to leave it, as the strutbrace got in the way for the plug above the reservoir. Gunson's had a perfect pre-fit so that kit made my day.
Old 13-06-2012   #8
Rallying Crazy guy
Re: Brake Bleeding
UPDATE, had the engine running while bleeding the brakes (to make sure abs pump worked and also to charge the battery) brake is now nice and hard, straight away the car was booked in for an mot, just waiting until tomorrow to find out if it passes
Old 14-06-2012   #9
Rallying Crazy guy
finally got some good news
Checked online this morning at the status of my stilo's MOT, as we never got a call to say it was ready, and it passed, woohoo,
brakes all round, New caliper on back, New brake servo and master cylinder, rear axle bushes and a couple of new brake pipes,
so all in all, I'm a happy stilo owner again!!
Likes richydraper, Shadeyman liked this post
Thread Tools
(T) Brake Bleeding Phil R Barchetta 2 24-05-2011 16:38
(T) Brake Bleeding Problem david295 Punto (Mk2/2b) 3 30-10-2010 19:32
(T) Brake bleeding help!!!! DORSETVDUBSTER Multipla 1 07-06-2009 22:53
(T) Brake Bleeding Aldino X1/9 3 25-08-2008 18:12
(T) Brake System Bleeding dawozere Punto (Mk2/2b) 1 15-03-2005 14:00
