Anyone fitted non-OEM reversing sensors on a 3 door? If so, do you happen to know the colour of the reverse LIGHT wire?
I can't find it on any search and the eLearn CD doesn't help.
There was a loose wired connector on the off-side which may be there for a reverse sensor unit but I didn't feel like checking it out!
Is off-side the same as right side? Why are these terms actually so common?
Please did you find a good way to bring the sensor cables inside? One solution shown in other thread is simply trough the hole for the light cluser, but sounds that could make the seal less hermetic and leave water in?
Anybody knows which route in the factory fitted sensors would use?
Thanks, Cheers, Roman
