hi looking to purchase performance chip loads on ebay looking for recommendations ??? thanks keith
I hope you don't mean the resistor "chips" , they're just simple 10p resistors which are connected instead of the inlet air temperature sensor and simulate a lower air temperature - the ecu will make the air-fuel mixture richer but your lambda sensor will correct this again, waisted money in my opinion!
you obviously took the time to read who yellow quoted
mmm Guiness. Im off to the pub.
am I right in thinking these resistor chips youre on about would have to be connected to the maf sensor cable whereas these digital tuning boxes connect to the common rail.
the resistor is connected instead of the intake air temperature sensor (not the airflow sensor) - this way the ecu thinks it's cold outside and adds some more fuel to correct for air density/temperature.
The self-learning of the ecu will (partly) correct the richer mixture again by adapting the fuel injection timing.
A digital tuning box alters the signal towards the ecu actively depending on the incoming parameters - compared to the simple fixed resistor this is a better way to gain power however there are great differences between the various existing types....
It's integral within the MAF itself which would, as far as I know, make it extremely difficult to access.I think I would understand better if I knew where the intake air temperature sensor is on a JTD can anyone enlighten me.
Totally crazy idea anyway
I'm not really certain but I don't think such a device has ever been sold for the JTD. The common 'trick' on the JTD is to increase fuel rail pressure which is the box Shadeyman keeps going on about.So it would make it very difficult to attach a resistor type of chip into the plug like they do and still have the plug connected to the maf sensor
Keith,
did you get your tuning box in the end. If so what do you reckon to it. I can recommend the ItalianSpeed box if you are still looking.
