Now I see what you mean
That's great, works exactly as the 10 cents resistor you can use to lie the ECU, that the engine is still cold and hence increase fuel flow.
So you can't, in any way, expect better milage
I hope you won't get any problems with the injectors, cause the rail is designed to withstand much higher pressures than those it operates with, bud sadly, the injectors have a very tight operating limit(capacity). If you put too much fuel, you won't have the air to burn it (in your case the boost) and hoopla your engine goes into safe mode, but the "power box" continues to lie to it and guess what happens
I don't know how you pass the emissions test, when you burn more fuel and in some cases have some unburned fuel? The remap is a totally different thing, to make a real good remap you'll need to test your car on a dyno and not just get a ready mapping table. Everything in your car is well calculated, size of turbo, size of the intercooler, injection timing, this is a really cheap trick that could have consequences
