Hello.
I am having a strange problem with the driver's door.
Since 2002, (when I bought my Stilo) I have set the menu to speed Lck so the doors are locking automatically when the car's speed exceeds the 20 km/h (I own a 5D, 1.2). Normally, when I open the driver's door (from the inside), all doors will unlock (when Drv Lck not activated from menu).
Since last month, I am having the following problem. Usually early in the morning, the doors will not unlock when I open my door (driver's). Not even the internal light will light on nor the door light (the one located on the bottom of the door). For some reason, later during the same day everything works fine.
Someone told me it could be battery problem, but the battery is new (a few months old).
Is there a contact inside the door that may be loose?
Thank you
Thank you
