Right, had some success with this and no more clunks/creaks (for the moment anyway)
It is quite easy to replace the circular cup (which on mine was falling apart)
All you do is:
- Unclip the cup retainer (just lever clips on face of clutch pedal)
- Now pull the end of master cylinder push rod down (moves about 1 inch)
- Use your fingers to slide the white plastic cup out.
- Fit the new one (easier putting it in then taking it out)
- Mover push rod back to correct position and click cup retainer back.
Bye the way, you were spot on about the return spring. I looked at it closely and would've sworn blind it was an extension spring but it turns out to be a compression spring. Just as you suggested, it's located in such a way that it keeps the pedal in contact with the clutch switch (critical for this) but also provides very slight assistance when pressing the clutch all the way down.
I did try to the change other part too (mine is slightly broken) but was forced to give up when I realized just how much work is involved. All pedals need to come out including the accelerator (no captive bolts
) and I'd think also the BC. Would be far easier in view to bleed the master cylinder.
Putting the spring back alone was a god-damn nightmare and took 3 hours as I was forced to find a means of compressing it :bang:
