FIAT Auto Specialist Team
Old 11-04-2008   #1
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Brake light bulb replacement
Got to replace the drivers side brake light bulb on Mrs Ffoxys 1.2 Stilo. I saw a Thread about it not being reeeelly easy and that the Owners Manual mentions how its done.
Any of the Stilo massive got any tips...?
Best method... special tools... time to do (as its probably going to be raining and the garage is full up!) Best to do both at the same time or replace all the rear bulbs while I am at it with Bosch?
Cheers Stilo boyz...
Ex Suzuki SV1000S jockey, now a former 1.9 MJet Grande Punto Sporting pilot curently driving a Hyundai i30 1.6 Premium.
Ffoxy is offline Reply With Quote Quote
Old 11-04-2008   #2
PNL
Banned
PNL's Avatar
PNL has donated!
Cool Re: Brake light bulb replacement
Long extension and plenty of patience..watch you dont drop any of the nuts when your on the way out ..
PNL is offline Reply With Quote Quote
Old 11-04-2008   #3
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Quote Originally Posted by PNL View Post
Cheers bud... I just luv the FIAT way of bulb fitting lol! Trouble is most manufacturers are doing the same now!
What size socket do I need to fill with chewing gum and stick on my extension to get the nuts off and out without losing them and creating a rattle - tub?
Old 11-04-2008   #4
PNL
Banned
PNL's Avatar
PNL has donated!
Quote Originally Posted by Ffoxy View Post
Off the top of my head 10mm
Old 11-04-2008   #5
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Cool... well thats a starter for 10...
Old 11-04-2008   #6
PNL
Banned
PNL's Avatar
PNL has donated!
Here's a diagram as well so you can plan your attack..
http://www.spangerum.com:7080/navi?M...OD=0&DRW_NUM=2
Thanks Ffoxy thanked for this post
Old 11-04-2008   #7
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Cant connect to the origin Webserver... Its starting to go wrong already...
Old 11-04-2008   #8
PNL
Banned
PNL's Avatar
PNL has donated!
Eper top of the page..^.. although I use my own in my favourites as the site one done often work for me ..
Try this link..
http://www.spangerum.com:7080/navi?C...I_LANG=3&RMODE=
Old 11-04-2008   #9
It's about GO! not SHOW!
Argonought's Avatar
Argonought has donated!
The job's much easier than you think (at least on the 5 door) once you get over the shock of having to remove the whole light cluster.
10mm short spanner and socket does it - no real problems.
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: FALKEN ZIEX ZE912; Oil: Mobil 1 TD 0W-40 fully synthetic
Argonought is offline Reply With Quote Quote
Old 11-04-2008   #10
Paparrazi
Neil Barker has donated!
It's a really easy thing to do - just need a socket set with an extension rod and a 10mm socket. Pull back the boot liner, undo each nut, being very careful not to lose them into the abyss below, disconnect the multi-plug wiring and then withdraw the entire lamp unit from the rear of the car.
Then you just need to separate the bulb holder from the light unit and change the relevant bulb.
To use the delightful Haynes manual term, "Refitting is a reversal of the above" - but it really is that easy to do.
I'd be surprised if it takes you more than 1/2 hour to do, to be honest.
Neil Barker
Techno Grey 3dr Abarth Selespeed now replaced by a 2008 Toyota Avensis TR 2.2TD
Sadly, I am unable to recommend Sunwin Fiat Derby due to my experiences there
Neil Barker is offline Reply With Quote Quote
Old 11-04-2008   #11
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Thanks to Neil and Argo... Coyotes has sorted me with a walk thru and there dont seem to be any hidden pitfalls, just as Mr PNL says... plenty patience and care!
Thanks Stiloboyz!
Old 11-04-2008   #12
Camelot Knights has donated!
as soon as you have loosened the nuts you con take them of by hand so they dont fall,i did mine about 3wks ago i changed both sides in less than an 1/2hour.
Camelot Knights is offline Reply With Quote Quote
Old 11-04-2008   #13
Sounds terrible. Glad I have a multiwagon. No tools required and a 2 minute job to change any bulb in the back.
I can remove the bulb holder from the light unit with it in the car. It just clips in. I thought they were all like that.
john55 is offline Reply With Quote Quote
Old 11-04-2008   #14
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Quote Originally Posted by john55 View Post
Welcome to the future....
(T) Brake Light Bulb little_mo Stilo 25 15-06-2007 09:10
(G) scudo/dispatch 55 plate heater controls light bulb replacement abarthmark Scudo 0 01-01-2007 17:55
