lower it??
or keep it standard??
you decide!!!
going to try my best to get it lowered and cambelt/serviced by the time of donny then, got quite a challenge i think!:slayer:
So did you change your rear dampers or only the fronts?I fitted Eibach springs with Boge shocks and although the shocks are OK, i think the overal handling could be better with eibach shocks.
"Been there and done that" as they say
If you really want to lower it then make sure you go for Eibachs -30mm rather than cheap springs.
I'd also up-rate the dampers on the front at least.
I used cheap Pi springs which was a big mistake (nearly 40mm drop) even if the car did look better :bang:
It was pure joy to get back to standard springs afterwards - could actually push it through those fast curves again :devil:
To be fair, I personally thought the springs were quite good. They're very progressive (you can carry huge loads with them) but I made the mistake of not changing the standard dampers which meant the car had difficulty keeping the rubber in contact with the road (which is obviously not good for handling ).PI's no good then? My mate swears by them on his Coupe?
2) If you do change your springs, don't bother with spring compressors. Take your struts to a garage and ask them to do it (even they will struggle unless they have a commercial press). The Stilo standard front springs take a lot of compressing and most DIY compressors can't 'squash' the springs enough to free up the top mount to allow them to be removed from the strut...
