Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Fiat Stilo JTD Cambelt Change<!-- google_ad_section_end -->
Published by yampug
04-08-2009
Unrated
User Rated:Unrated
Some pics of my recent cambelt change hope they help.
Rought order of process.
- remove covers
- disconnect battery
- remove washer bottle
- move coolant bottle
- remove ecu
- remove one glow plug to aid engine turning over
- remove aux belt by removing bottom wheel with the 4 torx bolts in lots of tension in this so be carefull.
- remove timing belt cover
- line up timing marks
- slacken tensioner
- fit new belt adjust tensioner
- turn engine recheck tensioner
- refit all other components
took about five hours not done one of these before was awkward to remove the aux belt and setting up new tensioner is a pain. removing glow plug was pain too probably if you can turn engine over with out removing one try that instead as mine were seized in pretty solid and are a pain to access.
timing belt kit cost 125 from desira including new tensioner and roller. aux belt was 16 from local motor factors.
Thanks gerardh66 thanked for this post
Old 04-08-2009   #1
Super LOL!
Stu DemonD's Avatar
Trader Rating: 1
Stu DemonD will never be forgotten
Stu DemonD has donated!
Jigsaw: Chess Pieces Champion
Re: Fiat Stilo JTD Cambelt Change
Aargh, you didn't attach the pics - let me sort it out ....
See you next Tuesday
Stu DemonD is offline Reply With Quote Quote
Old 04-08-2009   #2
yampug has donated!
Quote Originally Posted by Stu DemonD View Post
Go for it i got cheesed off trying to upload the pics to the fiat forum site so gave up and used photobucket, fiat forum only lets you upload 5 pics at a time and by the time you write some text the system has lost the pics, guides thing sucks, be much easier just to write a normal post
06 Croma 2.4 200bhp
54 Stilo 1.9 multiwagon
yampug is offline Reply With Quote Quote
Old 13-09-2009   #3
jonathanbees has donated!
just done mine todat managed it all in 5 hrs
found it quite easy (why pay the stealers)
jonathanbees is offline Reply With Quote Quote
Old 08-10-2009   #4
yampug has donated!
What happened to you sorting out the pics Stu?
06 Croma 2.4 200bhp
Old 25-08-2012   #5
without a guide to follow this is not a job for an amateur , what happens if they lose diesel pump timing never get the car started.
DRIVE ME CRAZY is offline Reply With Quote Quote
Old 25-08-2012   #6
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Quote Originally Posted by DRIVE ME CRAZY View Post
Diesel pump doesn't need timing.
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW) - 5 of 215/45-17 Alloy Wheels
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 25-08-2012   #7
is it controlled electronically ?
just had a look at your autodata photo ip/fp has timing mark !
Old 25-08-2012   #8
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
The engine mounted fuel pump is just a very high pressure pump. It has no distribution role so it doesn't need to be timed.
Injector opening is controlled by the engine management ECU which sends a PWM (Pulse Width Modulated) signal to the injectors.
All passenger car diesel engines sold in Europe have used this method for many years.
Thanks vladof thanked for this post
Old 25-09-2012   #9
It's more commonly called a common rail diesel.
Stilo man is offline Reply With Quote Quote
Old 16-11-2012   #10
driver33 has donated!
I have done a few JTD timing belts and they are relatively easy (a lot easier than an Alfa twinspark or even the 1.2/1.4 16V petrol). The Alfaworkshop guide is useful (same engine):
http://www.alfaworkshop.co.uk/alfa_jtd_cambelt.shtml
I never bother taking a heater plug out. Taking one out only stops one of the four cylinders from going to compression.
Current fleet: Alfa GT Q2, Alfa 156 Sportwagon jtd 16V, Alfa Spider 2.4
Projects: Alfa Spider S4, Matra Murena 2.2 142
driver33 is offline Reply With Quote Quote
Old 16-03-2013   #11
haxman has donated!
Just a quick note about the idler pulley. There is an earlier and later type pulley fitted on 1.9 jtd 8v Stilos up to engine number 3646771 (fitted 15/05/2003) If you have an earlier Stilo you may need to make sure the timing belt kit you buy has the correct parts. I dont think they supply the earlier pulley any more, you get given the later type but you will need a different bolt and washer to fit it.
More details can be found on this thread:
https://www.fiatforum.com/stilo/3201...26-jtd-8v.html
Thanks Davren thanked for this post
Likes KungFooPanda liked this post
haxman is offline Reply With Quote Quote
Old 25-12-2018   #12
Czech Republic
Can you reupload images? Thanks
roll is offline Reply With Quote Quote
Old 12-07-2020   #13
varesecrazy has donated!
Photobucket : lost photos
Use the forums own hosting
Comment
Search this Guide:
(G) JTD Cambelt Change - very cheap! katanabandit1 Stilo 11 26-10-2008 23:40
(T) JTD cambelt change LarryB Stilo 4 19-08-2007 12:48
(G) jtd cambelt change Steve-0 Punto (Mk2/2b) 4 17-07-2007 22:34
JTD Cambelt Change Rockbottom Garages 0 09-04-2007 19:55
(T) JTD 130 Cambelt change DaveFareham Marea 4 12-10-2004 21:13
