jamie86 said:Don't break my hoist
arc said:1242 8v, 75 bottom end (stronger than 60), 75 cam, ported and gas flowed head, skimmed to limit, multiangle cut valve seats, lightened flywheel, port matched inlet manifold, then of course the 40mm TB and chip from the old engine
also upping the cooling, new alloy rad, puntoGT fan switch and a low temp thermostat
arc said:alloy rad from GCB in Bradford (01274 733 727). Low temp thermostat was made for me by Pete (fixitagaintomorrow). this thread should put you in the right direction: https://www.fiatforum.com/showthread.php?t=25351
