Hi there, I've got a 2000 punto 1.2 8v injection, just did the head gasket on it and now it's not running right.
Symptoms are,
Runs very sluggish, especially when at low revs and will cut out if revs aren't kept up when taking off.
Starts fine and will tick over no problem.
There is a lot of lag at low revs and is generally under powered.
I thought it may be fuel as it was sitting a while with an almost empty tank and I put some dodgy fuel in it, its now got proper fuel in it but is still running crap.
I had the timing checked on it by a delphi diagnostics kit and it is reading 10deg BTDC.
Is 10 deg BTDC right?
If not what's wrong with it?
Duncan
Symptoms are,
Duncan
