General punto gt turbo project
puntogt1
i thought after having a 2.0 nova and go for one of theses. i brought it as a none runner as the turbo and headgakset was gone and loads of other things gone on it.
thats sort of what it looked like when i brought it but this is it now.
i now got the engine running which i now is running stage 2 tuned. its cammed s/s straight throw evo front mount t25 garrett turbo fse regulater chipped and much much more.
That intercooler is a bit obtrusive - even the SEB4 guys running 220+ BHP get by with something more compact.
Otherwise, very nice looking car. I really like the alloys; it's difficult to find aftermarket alloys that do suit nicely.
the colours faded so im gunna polish it when i get around it lol. the only reason why i went for that intercooler was because no one else done it so i thought il be diffrent.
any1 else got any idea what i should do to it next.:confused: im order my 270cc injecters and 255 walbro feul pump next week so it shoud be going even better :slayer:since i had it i done this to it:
cammed
chipped
evo front mount
garrett t25 turbo
fse feul regulater
270cc injecters
walbro fuel pump
12 row oil cooler
dump vavle
s/s straight throw
de-cat
k&n
over size pistons
uprated lead
uprated plugs
uprated vaccum hoses
adjustable acturater
earth lead kit
bleed valve (14.7 psi)
and theres props more i havnt sed. i also had the head stripped and rebuilt with all new gaskets the all vavles been reseated.
been told this would be stage 2 but not 100% sure. any1 got any sort of idea what bhp this would be befor i put it on a rolling road?
lol the alloys are o.z and yeh mate its lowerd 45 mill all round
the intercooler doesnt look that bad. the pics dont do it justice but now its cleaned up and moved straight, it dont look that bad now looks better then wot it does in the pic.
ive came across a problem, every time i connect the vacum hose for the dump i rev it and the revs drop down really low and sumtimes cut out? but if i leave it of and block it up and run waste gate noise its fine. i tryed 3 diffrent dump valves on there and there all the same but work fine on othercars. any1 help?
it ran fine a while ago and i dont no what i done lol. still the same vac line which it started with.
sorry to but in but you dont hav a standard turbo rite,well my gt hasnt had a turbo at all and im thinking it wil need 1 soon! so if it needs replacing how do u now wot one will fit and wot sorta prices are they? also would getting a diferent turbo mean the ecu wouldnt recognize it??
The ECU wont care about the turbo as long as the manifold pressure is within the limits it expects to see. There's no point in fitting a bigger turbo without a new ECU and throttle body intercooler and inlet manifold.
Over boosting will cause the ECU to cut the fuel flow and a big turbo just gives more turbo lag. Standard size turbos are usually more than big enough for the job.
