Hugh surprise but Fiats S/S isn't working right, I'm fairly sure Fiat use the same system across all models with it fitted.
Goes like this, 2013 Punto bought last year had the original battery and S/S never worked. A few weeks ago I bought a new AGM battery for it (same Ah as original but supposedly better than the EFB factory fitted).
After I fitted the battery I left the S/S sensor left unplugged overnight to allow a reset. Morning comes, plug it in, drive about a mile and worked perfect, came to a stop and the engine stops. It will do this for an entire journey stopping and starting every single time. However if I then park up, come back to car and set off again S/S doesn't work no matter the distance driven or if I have all accessories switched off. If I unplug and replug the sensor in before setting off it immediately works and once again will S/S every time I apply the handbrake and put it in neutral.
Clearly the S/S system thinks the battery is up to snuff, I queued in a drive-thru recently and it start/stopped 4 times in a row, only rolling about 5ft forward at a time so battery is definitely tip-top. It just seems to forget this information unless I replug the sensor each time
Any ideas?
Any ideas?
