Old 20-02-2004   #1
gearbox problem
I have punto 75 sx m reg 1200cc. When i put it into 5th gear it is just like neutral there is no 5th gear (it is a 5 speed box).
hope somebody can help.
[V]
ton_g is offline Reply With Quote Quote
Old 20-02-2004   #2
Trader Rating: 10
dave has donated!
Hi welcome to the forum:)
check your linkage rods one may have popped off
Please do not Email or PM me asking for support. Post on the forums instead. Your reply may help someone else. Thank you
Old 21-02-2004   #3
are there more than one linkage rod ? if so where are they.
the one on the gearbox seams to be ok?
Old 22-02-2004   #4
There are likely to be 2 cables as well, the thinnest of which is probably accidental reverse selection inhibit.
Unfortunately the cheap Porter book I'm looking at doesn't really help much beyond that.. there's not enough detail in the small fuzzy diagrams, or instructions for setting up or adjustment.
I'm still undecided if it was worth the 2 UKP..[:0]
John H is offline Reply With Quote Quote
Old 22-02-2004   #5
don't think theres an "accidental reverse inhibit" isn't it lift-up reverse?
try a haynes manual
Met Cognac 99 Brava 100 HSX, wish it'd clean itself!
mad_colm is offline Reply With Quote Quote
Old 23-02-2004   #6
push-down reverse, impossible to select by accident.
Spirito di Punto | M-reg 55SX, black, 5dr. Clear repeaters. Remote locking fitted, no light confirmation yet though - need relay fitted
pritch is offline Reply With Quote Quote
Old 23-02-2004   #7
I got car last week do you think the gearbox could have been replaced with 4 speed:I
if so how can u tell
Old 23-02-2004   #8
Take it back.
AFAIK all (manual) Puntos are at least 5 speed - some are 6.
Old 23-02-2004   #9
do u think it may need new gearbox:(
Old 23-02-2004   #10
I'm new here as well.
If the car is still under warranty, get it replaced under that.
kibblybibster is offline Reply With Quote Quote
Old 23-02-2004   #11
is there any nosie's coming from the gearbox or has it leaked. i blew my gear box and i only blew 1st and reverse gears but the others worked fine. you might have blown a diff. and when you got the car did you not test drive it? you should always go through the gears to check for any whinning nosies you might have a dodgy gear box not uncommon for a fiat!! you can't take it back if you signed a recipet saying sold as seen. plus i think for £25 you could have got the AA out to check it!! would have saved you alot of money before you bought the car. gear box rebuild is expensive if you have blow a diff its a matter of time before the rest of them go
Damn right im good in bed i can sleep for days!!!! :)
sexybluepunto is offline Reply With Quote Quote
Old 23-02-2004   #12
Old 24-02-2004   #13
no noise runs well just no 5th gear[:(!]
Old 27-02-2004   #14
thankyou for all your help.my friend nose a guy that workes with gearboxes.he fixed it for £60.in the car.he took the end plate off the gearbox and used a tool made for punto gearbox:D
Old 28-02-2004   #15
on my punto it would not go into reverse and it was acting like a 6th gear. u basically got a linkiage problem it will cost u about 60 pound to get fixed
Punto 1.6 Turbo
Coshstar is offline Reply With Quote Quote
(G) Mid-throttle injection problem in Lancia Y10 FatNote Panda (Classic) 26 30-07-2004 18:58
(T) GearBox problem pomelcek Bravo / Brava 4 23-05-2004 21:16
(T) Gearbox Problem (More) dawozere Cinquecento / Seicento 1 16-01-2004 05:26
(T) Gearbox Problem dawozere Cinquecento / Seicento 2 16-01-2004 02:52
(T) very loud problem from gearbox area dumbo-the-great Punto (Mk2/2b) 2 27-11-2003 05:27
