Thread Tools
Old 29-06-2006   #1
Exhurst blowing at front and oil leaking somewhere close to it!
can you help about 10 days ago my exhurst started blowing and now oil is leaking from near the sound of the blowing.
Any idears?
FIAT (Fix It Again Tomorrow)
rossco is offline Reply With Quote Quote
Old 29-06-2006   #2
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
Re: Exhurst blowing at front and oil leaking somewhere close to it!
well theres really little i can tell you.
go underneath and try to see where its leaking oil and where its blowing.
oilcould be from many areas.check the obvious like the filter is tight also the sumplug
Old 29-06-2006   #3
If your exhaust is blowing are you sure it's not just a water and carbon mix that'll come out of the exhaust? (I know it's a long shot but maybe )
Alternately if you've hit something (like a speedbump) you may have smashed your exhaust and hit the sump at the same time....but I hope not
Thompatruck is offline Reply With Quote Quote
Old 30-06-2006   #4
i take it a broken sump and new exhurst is going to be costly?
I cant recall hiting anything recently or even ever in my punto!
Badger in my Citroen AX caused some damage mind!
If sump is bost, what is the rought cost of new one?
Old 30-06-2006   #5
custard's Avatar
Trader Rating: 1
your getting ahead of yourself.you havent even looked yet i assume
Thread Tools
Die Hard!!! The Negotiator Leisure Lounge 27 24-04-2006 23:20
(G) fiat ulysse oil and filter change jamx2 Ulysse 10 03-10-2005 23:18
(T) Oil leaking problem CinqoSX Cinquecento / Seicento 8 23-06-2005 19:21
(T) oil sensor failure / engine disaster Heather's Stilo Stilo 24 07-05-2005 01:16
