Hi guys. Got the 'majority' of it sorted yesterday evening after work. New boot on the driveshaft, driveshaft is back in after much effort. *sigh* & finally engine is remounted with new engine mount, it is all looking straight, just need to fit the clips around the boot as they were a pain in the backside & I gave up with them & I need to reconnect the clutch line.
Heres the problem im having; it looks like the hose and just been pulled out by the engine falling, I can see it is a spring clip fitting, but there are no grooves on the actual hose termination, it sort of just slides into the slave and can be pulled out quite easily with no effort?
The end of it looks like this (photo attached)
Can someone help me here? I'm quite confused.
Thanks all by the way, first proper maintenance/repair I've done on to my car and you've all helped me out a lot.
