Hi folks, I hope somebody on here might have come across this fault before and be able to shed some light on it for me. First of all I probably need to give some history so please forgive me for this next large piece of text...
My girlfriend's Punto Mk2b was constantly needing to be jump started if she did not use it for more than 2 days running. I had also noticed that on occasions the power steering would drop off and the small steering wheel shaped light would illuminate on the dash. This was usually solved by simply pulling over and restarting the car (but not always I might add).
As mentioned the car was regularly jump started and would run fine unless it was left for a couple a days however one day my friend jumped it for me from a spare battery he had and I'm pretty sure he wired it up back to front although he won't admit it. The headlights lights came on along with all sorts of dashboard lights etc. and there was a slight burning smell before I got out the car and yanked the leads off. When we reconnected them the correct way, the car started but as soon as we removed the leads it would die.
I installed a brand new battery as per the instruction in my Haynes Manual and the car started fine. I checked over the battery with a meter while it was turned off to find that the battery was draining. I solved this problem by removing a badly wired aftermarket radio (the constant live / canbus / lack of switched live problem). This has solved the drain on the battery however the power steering is no longer functional. My confusion is that there is no steering wheel warning light but the battery light remains on. I have also checked over the battery while the car is running as it does not increase in voltage above 12ish as I would have expected if the alternator was working.
From the history of the car I had assumed that the alternator was previously working since the car would run for hours after being jumped but now it looks like it isn't.
Ok, thanks for reading the whole way through. If you have any advice that could help it would be much appreciated.
