- May 1, 2014
- 273
- 170
hello guys,
I'm trying to have my clutch changed.
I've removed battery, battery trail, hoses and air filters, earth/ground cable, clutch slave cylinder;
But now:
1) gear ball joints:
how to detach them? Can I a flat screwdriver to pop them up? The tiny one seems a bit fragile....
After that, I have to remove the mechanism where the ball joints were fixed? It seems a bit bulky....
(photo1)
2) exaust manifold/pipe
Is it necessary to remove the exaust manifold and the turbocharger, or can I only remove the exaust pipe section that pass under the sump?
3) how to detach this one?
(by the way, what is it?)
(photo2)
5) is it necessary to spill out the transmission oil or can I avoid that?
6) Number of bolts to remove
how many and where are they?
Under the bell housing, front side: 18mm bolt and 13mm bolt; rear side: 19mm long bolt (dogbone) and a 19mm nut.
Above the bell housing, front side: 19mm bolt (under that thing at point 3); rear side: I have no idea, perhaps will I find something after removing the starter motor?
7) distance from sump to ground
How many cm I have to jack up the car to be sure that the gearbox can slide out?
Thanks in advance.
But now:
(photo1)
(photo2)
Thanks in advance.
