S swerve New member Joined May 21, 2014 Messages 9 Points 6 May 25, 2014 #1 all the side glass on my fiat punto elx 2001 has vin but the front windscreen and the rear have a another is this normal
S s and b Distinguished member Written 5 guides Joined Mar 13, 2011 Messages 7,620 Points 1,453 May 25, 2014 #2 swerve said: all the side glass on my fiat punto elx 2001 has vin but the front windscreen and the rear have a another is this normal Click to expand... thats very unusual you normally find its the screen and rear glass that have the vin the side glasses just have another set of numbers
OP OP S swerve New member Joined May 21, 2014 Messages 9 Points 6 May 25, 2014 #3 the front windscreen and the rear windscreen have to same as the vin plate but the side dont
KRaikkonenNo1 Patron member Joined May 27, 2013 Messages 673 Points 149 Location Conwy, North Wales May 25, 2014 #4 swerve said: the front windscreen and the rear windscreen have to same as the vin plate but the side dont Click to expand... that's sounds correct, the side windows dont have vin numbers, just glass numbers from factory
Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,186 May 25, 2014 #5 Could be that the side windows got smashed and had donor windows fitted Ziggy
fingers99 Patron member Parked in the garage Written a guide Joined Mar 20, 2006 Messages 27,743 Points 4,560 Location Liverpool May 25, 2014 #6 I'd suspect a breakage at some point in the car's life. Not something I'd worry about unless there was a leak!
