Hi Guys
Wonderful forum this is
I recently bought a 2001 punto 1,2 8v. Its run ok, but the engine seem a bit funny. i believe the hg needs to be changed at one point.
But at the moment im having a leak. It came all of a sudden some weekes ago were it ran hot. Since that ive changed
- Water pump (was leaking)
- Cambelt + tensioner
- o ring and the metal tube.
- Thermostat
No visible leak, all pipes are good, water temp feeler is dry
BUT it's stil leaking, not from any of the new parts but looks to be from the gearbox. If i loosing the lid to the expansion tank, it stops after a minut. otherwise it drips for 10 mins or so.
As far i can understand there are 2 possibilities:
Faulty hg
Core plug broken
Can u guide to what is most likely ? i use the car everyday, only have weekends to fix it. Is it a difficult task to change the coreplug? i have most tools, but just 1 jack. How long would it take roughly and will i need anything else than the plug ?
Last thing - there is a bracket, shown in the pics. It looks like there should be sitting 2 bolts, but theres none. Should i fit 2, and could this cause the leak ??
Thank you VERY much
- Thermostat
Faulty hg
Core plug broken
Thank you VERY much
