Hi everyone. I've got an 01' Punto mk2 JTD. No seriuos problems with it so far, except for the clutch kit i've changed recently. So far so good.
Now i have this issue: i've bought some DRL's(daytime running lights-led's). Ive mounted them nicely, but can't get them to work properly. The thing is, that they have 3 wires for power. Ive connected one positive to lights, negative to battery ground, and the the second positive to a cable, which i believe belongs to ABS. Now the led's work when i turn the ignition on, but if i even touch the brake pedal, they turn off for about a second. So i need to find another constant power source under the bonnet, that would be ON when the ignition is on and vice versa. Maybe anyone here knows if there is such a wire anywhere under the hood?
Sorry for writing mistakes, English isn't my first language.
Thank you.
Thank you.
