Old 27-12-2011   #1
Netherlands
Accident
Last week I had an accident with my Fiat Punto MK2, luckaly there are no injuries, but the damage is bad...
I'm going to look at the car graveyard for several body parts.
The headlight, sidepanel, bumper and the bonnet need to be replaced.
Can I change these parts by myself? And whats the best way to do this?
Other tips are welcome.
Here is the picture of my car...
TT22 is offline Reply With Quote Quote
Old 27-12-2011   #2
Re: Accident
looks similar to my recent mishap, only you WILL need a new bonet.
Quote Originally Posted by William Penn
Right is right , even if everyone is against it; and wrong is wrong even if everyone is for it.
wamdue is offline Reply With Quote Quote
Old 27-12-2011   #3
Fiatpuntomk2b has donated!
Re: Accident
pretty easy repair, all bolt on iirc, would be ideal if you could find another black mk2 and have all the parts you need.Could also use this to do a front end conversion MK2-----Mk2b
FiatPuntoMK2b
Detailing Freak
Link to Members motors in Signature
Fiatpuntomk2b is offline Reply With Quote Quote
Old 27-12-2011   #4
Trader Rating: 5
fingers99 has donated!
Re: Accident
Easy enough. You may find the wings are glued as well as bolted on -- a hot air gun (not too hot!) and a long screwdriver will help.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 27-12-2011   #5
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Re: Accident
I'd be going to a scrappy thats for sure
Lights make sure you have same bulb type H1 or h7 and if you have fog lights that the new set also have fogs
The Bumper if money is tight - you can tape up for now
But the wing and bonnet are scrap metal mate
Good pieces to practive machine polishing on
ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 28-12-2011   #6
Re: Accident
When you get the wing off make 100% sure the inner wing hasn't crumpled. If it has moved (even slightly), the bolts wont line up and it will need a new inner welding in.
Dont be tempted to make do because the inner wigs absorb energy in a crash and will simply collapse when they have previously taken a big enough hit. Also you will never get the new wing and bonnet to line up so do the checks and if necessary bite the bullet.
DaveMcT is offline Reply With Quote Quote
Old 28-12-2011   #7
thats Jip Zero
jip0's Avatar
jip0 has donated!
Shape Shooter Champion
Re: Accident
as said its all replaceable at home, iv done it and im rubbish with cars it is a fiddly frustrating job though
its a massive help if you can take the wheel arch liners out to get to some bolts, when i did mine i couldnt
take note of WhiteSei!
Looking for Mk2 601 nero black front bumper PM me
The Car
Quote Originally Posted by custard View Post
get a pic up,I'll tell if its big
Quote Originally Posted by Kier View Post
I rather like the look of the wood :
jip0 is offline Reply With Quote Quote
Old 28-12-2011   #8
Burkina Faso (Upper Volta)
Re: Accident
its ridden over the chassis leg so only needs the usual bits
clean up the screw heads in the liner with a wire brush and slightly tighten them before undoing them is always a good idea to break the rust,try and get some oil on the fasteners too if you can where they are exposed
you will need to take the charcoal evaporator of its fixings t9o get to the hidden bolt holding the wing on and if its an original wing you will need to cut the sealent to a panel too
get you new or s/h wing and you will see where the bolt hoes are,be very careful removing the windscreen trim and dont slip with the sockets or drag the wing on the screen as they are very susceptible to breakage here
straight forward repair everything bolt on cant envisage any problems for you a good scout on ebay should locate everything in your colour but be aware bonnets are best collected than transported by muppets in time warp machines
s and b is offline Reply With Quote Quote
(G) Had an accident! Melanabb 500 77 13-07-2012 18:21
Accident. Please help! kamkaps Lets Talk FIAT 10 22-01-2011 10:55
(G) Accident :S GP Egypt Grande Punto 1 21-04-2010 22:23
(G) Accident Help! marcellep Punto (Mk2/2b) 18 03-09-2009 13:04
