Stephen505
- Joined
- Dec 13, 2013
- Messages
- 74
- Points
- 20
I was driving in Sicily at 70km/h straight downhill road where there was a railway passing across. I saw the signs to slow down, but I thought they were meant only if a train is crossing. Since there was no train, I did not slow down and having no experience of rails, it was a terrible mistake.
The rails are not at same level of the street and as a result, my Fiat Punto had a big thump and hit the lower parts of the chassis badly. The oil sump was torn and oil splashed out. I stopped the car in 20-30 seconds.
I tried to start the engine again, started normally without any signs of strange noise of jammed parts in the engine, but there was the strange symptom as if one press the accelerator throttle and release it and so the engine revs at 3000rpm and stops in cycles of about once in 1 or 2 seconds (vrooom - stop - vroooom - stop - etc....). The only warning light is that of the oil - the engine warning light did not lit up.
I turned off and never started the engine again. Oil was still dripping. Opened the bonnet and there was the air-filter out form its place: snapped out from the holding brackets. I also had the silencer out of place from the central part of the car. Brakes were hard during those 20seconds, maybe I've broken a pipe too.
The car is finally at the mechanic's garage and is a bit reluctant if it should be repaired. He asked me several times if I think the engine was jammed / concerned, but I think it was not affected, since I heard it running 'well'. He said the other things are minor, but he is worried if the engine is compromised, and changing a new engine is expensive.
My questions:
1) What do you think about the accelerating symptom?
2) Would you repair it?
3) Anyone had a similar fault or experience?
Many thanks
Sadly
Stephen
My questions:
Many thanks
Sadly
Stephen
