I've just put a new engine in my 1.2 8v ELX. It's a direct replacement, using my ECU, Loom, Key etc. Everything is original bar the block and head.
The orange key code light is on constantly, I get fuel to the rail, starter turns the engine over but there's no spark so it's immobilised.
The red ecu light is also on (right hand side, underneath speedometer) but i'm not sure if this is meant to be on until it starts?
The battery has been disconnected for approximately two weeks and i don't have the code for emergency start-up. I bought the car requiring an engine but the key code light used to go off after 3 secs so it's definitely since the new engine has went in.
Any help would be much appreciated as to what to check etc......
:worship:
:worship:
