- Dec 12, 2009
- 336
- 86
I probably need to replace the clutch on my Mk2b.
here's the million dollar question - is it better to get it done by a dealer, or would any mechanic be ok?
I'm not so much concerned about the cost (although it is important) as of the technical ability / knowledge/ experience that a dealer would have over a normal mechanic. In other words, the dealer would probably look beyond the pressureplate/clutchplate/ release bearing kit and also check the seals.... would a normal mechanic do the same if he doesn't have specific Fiat experience?
Other question - on a Mk2b 1.2 8v, is it neccessary to lift out the engine in order to do the clutch?
thanks
thanks
