Bah, car broke again!
Got to work this morning to find all the passeneger side floor soaking wet, including the back!
The water is clear, no smell of engine coolant at all. Been looking round the card and found is comming in here at the front of the passeger footwell.
This appears to be connected to this valve under the bonnet
As far as i can tell this is the drain for the aircon, it only seems to drain when the engine is switched off. When the engine is running and the aircon is on water starts flowing into the footwell at a steady trickle. If i turn the aircon off the flow of water stops shortly after.
Im assuming this valve is not blocked as drains when the engine is switched off. Should it drain all the time? Is there a second drain/valve somewhere that may be blocked for when the car is running?
Any ideas on a solution would be greatly appreciated cause its way too hot in a black car without aircon!!
