gozzo
After taking my 98 ‘r’ reg 1.2 8v into the garage with very noisy tappits, they replaced the camshaft and holding mounting, re-shimmed valves to correct clearance.and he also cleaned the trottle housing, It is now when running at idle dropping down and reving back up to idle then dropping and stalling. But it isent doing it in any sort of pattern sometimes its fine then you can pull up at the lights and it will drop off again. But when the car is in gear it drives’s and sounds great. I was wondering if re-setting the ECU will do anything to help cure it. I have spoken the garage and they carnt fit it in for another week.
Thanx for any response
