Technical Power Steering Fix/Ongoing Investigation
Caithness
Hi all,
I may have a the beginnings of low cost fix route for some power steering failures that relate to the motor.
There are a lot of threads on this topic and I have read the EPAS stickied guide before posting.
Here's my story - sorry for the long post:
About a week ago, I turned over the ignition to start my X-reg 1242 Mia. I didn't crank it for long enough to start it, so I turned the key back and cranked it again. STUPIDLY, while doing this, I turned the steering wheel for some reason.
When the car started, the EPAS warning light was on - no problem, I thought, probably a brownout on the EPAS ECU, I'll just turn the ignition off then back on.... Light was still on :cry:
I disconnected the battery overnight, just in case it was a fault that could be cleared in this manner. Connected it back the next day - still on. The only other thing I could think of was that the EPAS ECU was possibly confused as to where the steering wheel was and that it may need proxy aligned...
Went to Arnold Clark FIAT in Aberdeen and got the fault read. Turned out to be :
Electric motor: O.C., S.C. to Ground or S.C. to +VBatt
At this stage I was hugely confused as to why this might be the case, the car has covered only 30k miles and had provided faultless service without the merest hint of impending failure; it seemed massively coincidental that the motor chose that precise moment to fail!
Fiat recommended replacing the entire column, but the fix cost seems an uneconomical repair given the market value of the car and, being a tinkerer, coupled with the fact that the fault was allegedly associated with a semi-serviceable component, I decided to have a look inside and see if I could at least diagnose the problem more specifically.....:yum:
Following disconnecting the battery again over night, I removed removing the lower steering-column shroud (via 4 Allen bolts) and was faced with the motor:
The motor wiring consists of two multiplugs, one which I assume is the supply with 3 hefty wires and a second connector which I am guessing is the drive signals for the (stepper?) motor. I unplugged both connectors from the EPAS ECU.
The motor is held in place with 3 Torx bolts (there is another one out of view at the top/back of motor photo - I used the height adjust to set the column to it's lowest position to get it more easily). I do not own a Torx bit this small, but I found an 8mm regular socket fitted perfectly.
After the last bolt was free, I removed the motor by pulling gently, taking extreme care not to rotate it as I did so.
I immediately took a photo of the motor shaft and noted that there was yellow paint on the splined shaft - I used this as a reference for refitting later:
Notice there are other things in here that one may not expect! Relays!
Running a Google search on these Siemens part numbers revealed an Italian site with a thread devoted to this and magnificent pictures of these relays. Not being fluent in anything other than ropey-at-best Scottish, I translated the page using Yahoo Babel translator. It's not great, but you can get the gist, besides the photos are the important bit:
http://66.196.80.202/babelfish/translate_url_content?.intl=us&lp=it_en&trurl=http%3a%2f%2fwww.pctuner.net%2fforum%2f1246844-post56.html
The first picture describes where you shouldn't see a short circuit. Being that these are hefty-looking power wires and that my fault is related to a short, this was my first series of tests. Sure enough, indicated by the continuity check beep on my multimeter, I had a short between pins 1 & 3 on my relay nearest the closest together pair of bolt holes.
I needed to get the PCB out the motor to test it properly so I desoldered the 6 power connections from the PCB and removed it:
Wasting no time, I then desoldered the relay (8 pins) and the add-on legs (worst design ever) :
...A super-careful dissection of the offending device then took place - first I used a scalpel to very, very carefully cut the base from the relay:
After doing that, I slid out the innards and found the contact arm to be melted in place on one side only, the right as you look at the picture. I gently freed it and noticed that, interestingly, the plastic had melted, not the contacts themselves:
Finally......
This was giving rise to the “short”! I carefully removed all of the melted plastic and rebuilt the relay, tested it extensively before rebuilding and re-installing the motor. I was satisfied that both were operating as good as new.
I made certain +/- 1 tooth that the splined shaft was reinstalled in the correct position then I checked and double checked the motor to EPAS ECU connections and then re-connected the battery. I started the car to be faced again with the warning light :bang:
Turned the ignition off then back on and the light was GONE!:slayer: I slowly moved the wheel from lock to lock, the power steering was a little jittery, but I am not 100% that it wasn't me being excited. However, when I got to the right-hand lock, the wheel seemed to “jump” to back to the left before the EPAS died again; several re-starts and back to square one. Tested the motor again, relays are still fine all fuses ok :cry::cry:
Questions/comments:
1. I speculate that, since it failed at the extreme position of movement, the EPAS ECU has somehow lost where the wheel position is, how can this be the case when I was so careful when taking out the motor and putting it back?
Surely only de-synchronising the TDC sensor in the upper steering assembly with respect to the encoders in the column could cause this? The motor shaft position is surely irrelevant being that it has no (evident) encoders.
2. Does anyone know this motor inside-out? Does it indeed have encoders?!
3. Does this fault give rise to a logged error that would explain why the light is on?
4. Does anyone know how this relay, multi-supply setup works? Is it like a DC windscreen wiper motor where, by powering a brush closer to the oppositely-poled one, the motor speed is increased, perhaps effecting “City mode”?
5. Any other factors I am overlooking?
Options:
1. Take it back to Fiat to be re-scanned and, if applicable, pay to have it calibrated and the fault cleared. I am reluctant to give Fiat another £29+ for this as it's a total gamble.
2. Take it to an independent garage and ask them if they can scan it and clear the code if it is stored - also a gamble, but it may be more justifiable seeing as this SC problem is now rectified.
3. Buy the complete column from Fiat (virtually unjustifiable when weighed against the value of the car).
4. a)Still very expensive - buy a BBA Reman 2-year warranted unit http://www.bba-reman.com/content.aspx?content=fiat_punto_brava_bravo_electric_power_steering_failure
b) I have read that this doesn't need calibrated since it is a complete system. Can anyone confirm or refute this? How can this be true, given that the rack position is integral to getting the steering position straight both physically and from the EPAS system standpoint?!
5. I have heard reports of diode failure as a common problem with the system, being that my EPAS suffered immediate failure with no preceding loss in performance and that a diode failure could be an effect or contributor of the relay failure. If anyone knows where this diode actually is, I'd love to know!
5. Continue investigations with the motor, perhaps replacing the relays with new units (the part now obsolete - ooh, I wonder why?!). That said though, to the best of my ability to test them, they are 100%.
Again, sorry for the long post, but if this route costs only the price of 1, or 2 at the most, diagnostics and a couple of relays, it sure as hell beats the several hundred pound “new column and that’s that” route and may help other people in the similar circumstance of weighing up getting rid of their pride and joy on the strength of this poorly designed subsystem failure.
Any and all questions and comments welcomed.
The EPS control unit 'sees' the above fault, but although it could be the motor or wiring it could also be the control unit, I have came across this on more than one occassion.
Ah, ok then, maybe the relay overheat/short had a subsequent destructive effect on a component in the EPAS controller.
There is no way of knowing this without another scan I am guessing, otherwise my time will be spent on chasing consequential faults when it could be more constructively used to order that BBA Reman unit!
Do you have any experience with this, or other complete, swapped-out units in terms of it needing/not-needing calibration in relation to the rack?
Thanks for your input T14086 - I do appreciate it
EPS is part of the CAN network so it needs 'proxy-aligned' as a result. Have had loads of issues with customers who have fitted columns from other sources, often all that is required is callibraton reset which should be carried out anyway.
Personally i'd use fiats examiner diagnostic equipment to 100% identify the fault, however as the column is only available as a complete unit you could say aslong as the wiring to/from the column control unit os ok it needs a column end of story.
A final note is I constantly come across problems with units sourced from dubious places (not BBA I should add here) which just results in more expense to the customer. If you do buy from BBA then it will still need aligned/callibrated (£40-45) so add this to the total cost.
EPS I think he means.
Yeah, just my nomenclature - the extra 'A' being part of the initialism for "assisted", as it is power-assisted steering.
Glad for the info - I'll take this into account
Very interesting thread - i have 2 faulty spare columns here - might have a look :D
I'd love to know more about the motors - are they steppers? It has lots of connections like one, but doesn't seem to be "notched" when it turns, unless the step angle is teeny.
If it does have integral encoders and I have messed up the motor position when I had it out, then that could explain things. :yuck:
Also, I'm not sure what those relays are doing either - they aren't acting as a crude H-bridge; they just seem to be switching one of the wire triplets into the other two. On each side. Simultaneously...:confused:
So we have 3 fat supply wires and 6 control wires for relay switching and other stuff I'm not sure about!
Beyond the PCB, it looks like you'd have to pry the metal sleeve from the motor body to see what was going on.
I've done 2 units now (hence my 2 spare faulty columns), both I managed to get away without needing calibration and they work perfectly and dead center.
Just a case of ensuring the doner cars wheels are perfectly straight before removing and the same with yours when refitting. Theres a notch on the shaft to ensure the steering wheel can only be fitted in one position. If the car pulls/steering wheel isn't center when trial-running it, you just need to disconnect the shaft-to-rack connection and turn it a tooth before reattaching. Its important to ensure the shaft isnt moved while its out for obvious reasons - it won't understand its 'centre' anymore, but other than that, its a pretty straight forward job.
I fitted a bba unit in april no problems todate ,last place i would go would be fiat.Personally when a manufacturer FIAT/VAUXHALL bring out a crap system like this they should replace it free of charge regardless of mileage.
yours geoff b
ps. iv'e heard pages do replacement colums
I am considering the BBA Reman entire unit to be the best route for me at this stage. There are still a few points I am not totally clear on.
1. When I remove my old system, presumably the position the steering rack is to be perfectly centralised so that the new column will use this as a reference point for its range of travel to either lock?
2. When I receive the new column, should it be in its absolute centre position - if so, how can I check this? Alternatively, does the column even care what its installation angle is set to?
3. When I put in the new column, how do I ensure that the the connection between the column and the existing rack are in agreement?
I am afraid that if I install the column and the position of it and the rack are out of phase, that the system will re-enter a fault mode and either be damaged or at least require alignment or calibration - I scared that if the range of the column is not set correctly with respect to the rack that, at the end of the rack travel the motor will try to keep on turning and that it will enter fault mode because of this.
BBA Reman say no calibration is required, others say it does need to be :confused:
Just make sure your wheels are pretty much straight forward (as best as you can.) The steering wheel will only fit on one way so that will give you a guide as to making sure the new column is also as central as you can make out by eye. at most you'll be a couple of teeth out, which will become apparent when you trial-run it, but dont use lock to lock or city until your sure its right.
...The steering wheel will only fit on one way so that will give you a guide as to making sure the new column is also as central as you can make out by eye. at most you'll be a couple of teeth out, which will become apparent when you trial-run it, but dont use lock to lock or city until your sure its right.
Hi again Xen,
Thanks for the continued highly-useful info.
Am I right in saying then that the column (on its own) can only measure where it is during any one rotation, rather than where it is globally in terms of the rack position?
Put another way, I could get my new column and spin the splined section all the way through 360°, any which way I want, so long as during the installation, I ensure that I rotate it so that the steering wheel key makes the steering wheel position straight?
If that's true, after installation, how does the column know it's at the end of the rack's range of travel and cease motor output? Does it count the number of steering wheel turns that the driver has made from the steering wheel's centre position?
Sorry for all the questions, but I want to understand how this system operates.
I'm not entirly sure how it works in that respect to be honest, but i was told by the recon guy that if it is rotated 360* either way, it would need recalibrating so he stressed to me to avoid moving the shaft as much as possible during installation.
BTW, ive completely dismantled one of the motors now and i'm working on a circuit diagram, so we should have a few more answers when ive finished :)
The motor is a little unusual. The amateur is a strong perminant magnet and its movement/position determined by 6 seperate field coils. So i suppose in essence it is a bit like a stepper, where by the position of the amateur can be held by energising one of the six coils (and possibly be energising the adjacent coil with the opposite polarity.)
I'm not entirly sure how it works in that respect to be honest, but i was told by the recon guy that if it is rotated 360* either way, it would need recalibrating so he stressed to me to avoid moving the shaft as much as possible during installation...
I'm pretty sure that when I receive a new column in the box, the starting position may well be unknown and I'll just have move it to the position that makes the steering wheel straight. I'll not have a clue what the global central position of was when it was calibrated! That is, unless they secure it and send it centralised?!
That's a cracking piece of work you've done there Xen :worship: With that information, we may start to see what the relays are actually doing -
  • They are energised in tandem (the energising coils are wired in parallel).
  • Of the 6 wires that come up through the motor, each relay connects the black feed to both the red and yellow feeds - essentially shorting all 3 wires on each side - simultaneously.
  • The relays then are energising adjacent coils with different polarities, as you have said.
Can you see where the big shielded (supply?) feeds go? Was it hard to get disassemble the motor?
