Thread Tools
Old 06-03-2008   #1
punto 16v head gasket head problems
ok, started head gasket got to taking head bolts taking them off in order, two stubborn head bolts the two bolts are now rounded off because they just wernt coming off.
i have purchased stud extractor drilled down and dropped it in, they both snapped inside the drilled hole, do i try and break the head of the bolt off? or does any one know any easier methods?
Thanks alot
philmoore is offline Reply With Quote Quote
Old 06-03-2008   #2
Re: punto 16v head gasket head problems
Look in the Yellow Pages for 'spark erosion'. There are few things in this world that are worse then the feeling you get when you break an 'easy out' inside a bolt.
It may be possible to grind the head off with a small die grinder like a Dremel etc. You'll still be left with the exposed stud to remove, but you'll get a better grip of it. The problem will be if the threaded portion shears inside the block...
I don't mind being wrong, but I hate it when somebody else is right.
rpaterson is offline Reply With Quote Quote
Old 06-03-2008   #3
Quote Originally Posted by rpaterson View Post
yea at the moment im just trying to drill the head off, its the most annoying problem that could have happend as you say should have been easy removal would a dremel bit be better ?
i already had one of the bolts out to look at the thread and it doesnt look like the thread is in the block as the blot just drops straight down so but the block will need a bloody good clean with all the metal shards
Old 08-03-2008   #4
Bravo 1.8 HLX FTW
The Sultan's Avatar
The Sultan has donated!
you didn't use a bristal bit did you should have asked on the forum first and i would have told you you need aircraft tools lol
make sure you get one before replacing everything or you will snap some more bolt heads into pieces
500 door handles fit bravo well chuffed
The Sultan is offline Reply With Quote Quote
Old 08-03-2008   #5
Quote Originally Posted by littlepip17 View Post
Alright mate, what do you suggest i use to get the stud out, i havnt tried drilling the easy out back out but heard its very diffictult and as above spark erosion may be needed to get it out. i have ordered a stud remover from ebay 10 do you know if they are any good or am i wasting my time, just need to get these two bolts out >_<
any help advide appreciated.
Old 09-03-2008   #6
Bravo 1.8 HLX FTW
The Sultan's Avatar
erm best thing i suppose is a small die grinder there is a washer under the head bolt so you can grind the head of the bolt completely down without damaging the head then once you have the head off and the tension is released off the stud it will undo out of the block with your fingers or a set of moles if a ittle coroded but by no means will it be stuck fast
not entirely sure were to get bristal tools but if you try to do em up with either tork's or ribbed you will snap one again
http://www.bristol-industries.com/index.html
this may help
Old 11-03-2008   #7
FINALLY GOT THE STUD OUT!
used a socket piece 1mm smaller than actuall size brought a bench grinder, ground the end down to make it nice and sharp, hammerd the socket in place then used a t-bar to undo.
About time, just as well the bolts get replaced
Thanks for all your help
Thread Tools
(G) How many Puntos are there on the Forum? - The Thread FiatStiloJTD Punto (Mk2/2b) 543 06-06-2008 18:15
