Maybe the information in this article could be of use?
http://www.autospeed.com/A_1836/cms/article.html
Now my theory is, I believe the GSR causes similar problems to the JTD as the Scooby in this article has.
Not because it's a bad design, totally the opposite! It's so good that the standard boost control setup can't cope with the extra airflow it's bringing in
When you floor it in 3rd or above at around 1800rpm you get a vibration from the clutch as it struggles with the torque, I'm thinking this is a boost spike like in the article as it goes away around 2200rpm.
Now if anything is damaging the clutch, this would be it; so by eliminating this you would be prolonging the life of the clutch. You would however sacrifice some peak torque but only for the overboost period if you set it up correctly.
Of course the alternative would be to buy an electronic boost controller but they are quite a bit more expensive than this option...
DISCLAIMER: I COULD BE TALKING TOTAL ******** HERE AND I'M SURE ONE OF THE MORE KNOWLEDGEABLE MEMBERS WILL TELL ME IF I AM OR NOT, OR WHAT THE OBVIOUS FLAWS ARE
