Not a standard HG query this one, My car on the face of it has no HG issues the temperature gauge is steady, the heater works, and there is no rainbow in the coolant, But Unfortunately oil appears to coming out of it Its been doing this for a while, when I first looked around the car with a mind to buy it there was a small oil stain on the block where the current leak I took it as a bit breathing through the seals but not a leak, Now its at the stage shown on the photos, the amount of oil the car uses is entirely dependent on engine speed and throttle position, If i use a 4.5k maximum change up point i can use as little as one litre every 6k miles but if you rev it more than that and use a lot of throttle you can use half a litre in 500 miles, I suspect it burns oil at high revs as well as spraying it out of the front of the block (I don't know whether oil could gain access to the combustion chamber through the gasket or whether its suffering from a bit of engine wear) Its done 64k and either way a haze comes out of the exhaust when you give it a boot under load and if all the oil was coming out of the front I think the wet patch would be much bigger. The question is whether or not its worth taking a car that is currently running fine to pieces to fix it? Or should I wait till it goes pop? Oh and its a 1998 85 mk1
