kincaidston
Got a 'R' Plate punto (mk1, 97) 60S.
For the last few months i've been noticing thats its been getting harder and harder to get the car in gear, not much but noticable none the less.
However in the last couple of days and yesterday especially it has been really hard to select gear to the point that to get into reverse without a huge crunching noise means switching the engine off, selecting gear and starting her back up again.
When the engine is off, gears can be selected easily with no trouble whatsoever. But with the engine on then it takes an amount of force to get out of gear and then select the next one. This is across all 5 gears.
As the car has a hydraulic clutch how would this effect the biting point?
I've been quoted £195 to replace the clutch, is this reasonable?
And in conclusion, do you agree with me that the clutch is the likely source of the fault?
