weewillywinky
Trying to find out what is causing the lack of power in my mk2 sporting. Have decided that the hotter the engine, the worse it is.
I have tested the resistance of the coil packs (at room temp), and get these values:
Primary - 0.9 ohms & 0.9ohms
Secondary - 14.08 kohms & 14.14 kohms
But my values are higher than the Haynes values of:
Primary - 0.52 - 0.62 ohms
Secondary - 6.83 - 7.83 kohms
Does my coil pack need changing? Is there anywhere else I could find the correct resistance values for this coil pack? Haynes only specifies these values for 8v and 16v coils, which are different
I would be very grateful if somebody else could compare the values of their mk2 16v coil pack with mine (it is a single unit for both coil packs), unlike the 8v.
Cheers.
Cheers.
