FIAT Auto Specialist Team
Old 09-01-2017   #1
Water running sound passenger side
I have just purchased a 2011 Fiat Punto Evo 1.4 Dynamic (5d Dualogic) with S&S, the car seems to be running okay, temperature gauge is normal and the engine sounds fine. I noticed after I bought it that the heater wasn't working (fan was blowing but there was not heat). I sent it to the garage who blasted it out with water, and then it seemed to work fine. Then this morning I started it up and pulled off, as I did I heard a sound coming from the passenger side (seems low down like it's by the bottom of the door) which sounds like running water. It seems to happen when accelerating from a stop or in low gears, and not when braking. Any idea what it could be caused by, and what the fox may be?
Thanks,
Dan.
danpaddy is offline Reply With Quote Quote
Old 15-01-2017   #2
Re: Water running sound passenger side
Did you get to the bottom of this?
Sounds like an air lock in the cooling system. You'll be hearing the air bubbling in the heater matrix which is in the centre tunnel.
bencey is offline Reply With Quote Quote
Old 16-01-2017   #3
varesecrazy has donated!
Quote Originally Posted by bencey View Post
@danpaddy
yes - it does..,
check the coolant level NOW.. as it may well be LOW
see the GUIDES for how to bleed the air from the system..should improve heater output also
Charlie - 2012 punto TA
(T) wet passenger footwell/running water sound! kaosNW Bravo / Brava 14 14-01-2009 12:43
(G) running water sound Sorted4 Bravo / Brava 10 07-06-2008 10:45
(G) running water sound Sorted4 Bravo / Brava 2 04-03-2008 11:33
The sound of running water Jacq FIAT Boo Archives 1 24-01-2008 15:13
The sound of running water! matt FIAT Boo Archives 7 05-02-2005 00:42
