Thread Tools
Old 09-10-2016   #1
France
Angry Slow mod ?
Hey there
I need some advice on some trouble i'm having with a Punto Evo 1.6 120hp 2011 120k km
I bought it about 1.5 month ago and i'm having some trouble
2 weeks ago I put some excellium diesel in it and the following day a faulty engine light lit up, I'm not sure it was linked to it, but read someone had that too the day after trying some premium oil... So idk
Anyway, after getting an elm and linking to my phone I had this result
Confirmed Trouble Codes
-P010F: Mass or Volume Air Flow Sensor A/B Correlation (Powertrain, Generic)
Freeze Frame
-Calculated engine load: 0.0 %
-Engine Coolant Temperature: 87 C
-Intake Manifold Absolute Pressure: 105.0 kPa
-Engine RPM: 2490 RPM
-Vehicle Speed Sensor: 109 km/h
-Intake Air Temperature: 24 C
-Air Flow Rate from Mass Flow Sensor: 24.25 g/s
-Fuel Rail Pressure: 51150 kPa
I was told to unplug and replug the maf sensor, I did so and cleared defaults
Thought I was good, but seems not.
Sometimes, I believe it happens after I deccelerate, the car gets into safe mod (max 3k rpm or even 2.5 depending what gear I am running), start/stop gets disabled and speed regulator too
If I stop the engine and start the car again, it goes as if nothing happened
There is no light or message coming up after it gets into safe mod, I tried to check errors with elm and found nothing
But, one test is wrong :
Mid$31 EGR monitor Test ID$80
min 38,502 max 43,827 my value 44,077
Could the safe mod come from EGR valve ?
How to know ? Could a garage tell me more than I can with elm ? I mean from reading the car ? Or will they have to guess with what I tell them, if they can't reproduce the thing ?
Could if be the MAF sensor ?
I don't know the car much, only drove about 1000km since I have it, but thinks it lacks some power, I mean before 1800-2000k rpm, I don't feel acceleration, turbo lag, or maybe DPF is dead, I don't know, but after 2k, it goes fast, and drinks alot, tho I try to keep it at 7.2l/100km
Also during that 1k km, I didn't have the dpf regeneration cycle to start, thought I read it's every 800-1000kms ?
I know the guy before me did his oil change himself, and service has been reseted when he last did, but I read there is some other thing than service to say you changed oil, and that if not reset, dpf regeneration wouldn't start, it that true ?
Just hope it's not something too pricy and that I didn't waste my money on a faulty car, I'm coming from an old 99 ibiza 1l 50hp that I couldn't see anymore
Thanks for help, if you guys have ideas...
Evo63 is offline Reply With Quote Quote
Old 13-10-2016   #2
France
Re: Slow mod ?
Anyone ?
Today the fault code came back with check engine message on board.
ELM gives a similar freeze flame from last time but it's weird because it says 131km/h, when I was at 50 when the fault code came ? Is it normal ?
Coude a freeze flame get memorised before anything appear on display ?
I'm really confused
Old 15-10-2016   #3
France
Re: Slow mod ?
So today I was able to use a computer and try multiecuscan
It found another fault code than android apps didn't in past
P0409
And I did record some stuff
I believe turbo is fine as desired and actual control position are similar
But the EGR is totally wrong !
Screen 1
Screen 2
Screen 3
I was worried it might be dpf, but it says 75% and normal clogging, says 100 isn't too bad but 200% is critical, anyway, seems I'm fine on this for now
I didn't notice any regeneration in past but it says it did 450km ago, that average temp for last 2 gen was about 650 and that it lasted about 530s
Now I'll try to find someone help me clean the egr and maf sensor and see if I get any improvements, if not idk if only egr has to be changed or also maf sensor, as first error code mention it, but I think EGR only ?
Old 15-10-2016   #4
varesecrazy has donated!
Re: Slow mod ?
Quote Originally Posted by Evo63 View Post
P0409
Screen 1
Screen 2
Screen 3
sorry - just seen your posts..,
sounds like using MES to reset the oil degradation , etc, will give the engine a better chance of running properly..,
I know little about the 1.6 engine..maybe look in the TECH section.. or SEARCH on here in "advanced" works well for specific searches,
Charlie
varesecrazy is online now Reply With Quote Quote
Old 15-10-2016   #5
France
Re: Slow mod ?
I'm not sure I can reset this thing, think it asks for yellow adapter/connector, but I saw next service in ~28000 km so In the end I believe oil stuff is ok
Anyway thanks for help, I'll also link my screens into the tech forum, maybe they can tell me more or ask for a wider input selection
Old 15-10-2016   #6
Re: Slow mod ?
Old 01-11-2016   #7
France
Re: Slow mod ?
Two people told me MAF sensor should be the problem, but to me, it can't be the thing causing EGR position to be wrong to desired one..
Even if MAF sensor is sending bad infos, shouldn't ECU recalculate another desired position ? And my EGR follow it ?
After investigating, I found the MAF sensor to be pretty clean, and looking closer, found manufacturing date : 09/2015 ....
Someone knew about this... EGR screw didn't seem new and it was dismount in the past, I removed it thinking it would be rusty clogged or would need some cleaning, but it seems someone did it before selling the car...
See by yourself http://imgur.com/a/UY7CU
Nothing compared to what I can see on google
So, without power it is fully open, I can close it with finger without too much resistance and also same strenght needed from 0 to 100% closed, so now I'm doubtful
Anyway I made it move for a while and reinstalled it, gotta have a ride to see how it goes, but doubt it changed anything
Could any professional tech confirm or at least give his advice on it ?
I'm pretty sure it's the EGR from last recording, but I don't wanna replace wrong parts and miss the real problem
Thanks for help
Old 01-11-2016   #8
Became old and sensible
MrDerv's Avatar
MrDerv has donated!
Re: Slow mod ?
Thanks for help
The reason it's probably throwing a MAF code is that the EGR value is high, and therefore more exhaust gas is re-entering the intake (possibly due to the 75% clogged DPF causing a flow restriction).
Give the EGR a good clean, as it's not uncommon for them to stick due to the soot build-up. Once cleaned, refit and clear the codes, you might get a better reading.
Get the yellow adapter for MES, there's a possibility you might be able to force a REGEN of the DPF, which should hopefully help things run smoothly.
Current Garage
Mine: 2013 VW Passat Sport BlueMotion Tech 2.0 TDI Stage 2 Mapped
Hers: 2007 Renault Megane 1.6 VVT Auto Dynamique
MrDerv is offline Reply With Quote Quote
Old 01-11-2016   #9
France
Don't you find the pics already pretty clean ?
This was just after dismounting
Sure I removed the little soot there was, but don't think it was blocking anything
Dunno if I need the yellow adaptor to do the force regen but I saw last regen happened 100km ago, tho I could try, or bring to carbon cleaning center or w/e they call it in english, they'll force regen for 45m/1hr with some product to help cleaning dpf egr etc.
Also are all color adapters usefull with elm or should I only get yellow one?
Anyway I drove a little now and no fault came back, yet, and it didn't go in slow mod when I tried (2x) to decelerate where it went slow last times
But I think curves still show EGR at wrong position, will check and upload them later today
Old 01-11-2016   #10
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: Slow mod ?
MES says you need an adaptor to do a service reset for Model year 09 but it's not clear if it's all cars after 09.
I don't know the 1.6, but the other 16V diesel multijets with DPF need an oil degradation reset as well as a service reset. If this is not done it can stop DPF regenerations regardless of the oil condition. You should reset the oil degradation and do a forced DPF regeneration to sort that out first. At least it does not need any parts. Next thing would be to take the EGR valve off and clean it. Bothe a blocked DPF or EGR valve will upset the airflow and possibly cause the sort of problems you are seeing. Multiecuscan is pretty much as good as anything a Fiat specialist has and better than most non-Fiat garages EOBD diagnostic equipment.
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 01-11-2016   #11
France
Re: Slow mod ?
Hey
I first thought about this reset thing, but it seems it does regeneration, just I don't notice it, but last one was 100km ago, and previous about 500-600, oil is at 80% and next change is said in 28 000km, so reset was certainly done
I just did clean the EGR, but think the previous guy did it before selling it, as it seemed pretty clean, compared to what I saw documenting on EGR cleaning
Curves I got
1
2
3
4
5
As before, EGR wanted and actual position doesn't match, and can also see that mass air wanted and mesured aren't correct, probably cause EGR won't open or close enough.
Old 01-11-2016   #12
MrDerv's Avatar
MrDerv has donated!
Re: Slow mod ?
That unit in the pic is NOT the EGR. It is an electric throttle body that is used to shut off the air intake when you turn off the engine.
Regarding the other adapters, It depends how deep you want to delve into all the other ECU's but yes, they are all handy. 15 for all of them on ebay i think
Likes Evo63 liked this post
Current Garage
Old 01-11-2016   #13
France
Re: Slow mod ?
Alright...
I wanted to buy the technical book, but seems 1.6 version doesn't have one (at least on french manuals), I found one for Grande Punto, but not really sure it would be the same
Think it could be under as in this video
Anyway, thanks for your time, I'll give an update maybe this weekend if I can work on it
Old 02-11-2016   #14
MrDerv's Avatar
MrDerv has donated!
Re: Slow mod ?
Alright...
https://www.youtube.com/watch?v=0v9zMtLvCQ4
The part removed at the end of that video is indeed the EGR valve. Good luck getting to it
Current Garage
Old 03-11-2016   #15
Re: Slow mod ?
Hi guys,
Im from Poland and i have the same punto evo with 1.6 mjt my egr after 30sec on idle turn off and actual air quantity shows 400 mg/i when i press gas it back to something around 200 but sometimes is 190 and sometimes is 240 and dont know why.. EGR? Evo63 can you put some short video of air quantity in cold start and hot engine with egr position?
puntoevodiesel is offline Reply With Quote Quote
Thread Tools
(T) Slow Acceleration Fault....But Not THAT slow! Simonf1973 Stilo 2 03-09-2010 22:45
(G) Legal vs Country (to mod or not to mod) RuiG Cinquecento / Seicento 6 06-06-2008 23:07
SLOW SLOW SLOW ben Latest News 99 30-07-2004 22:22
Slow, slow, quick, quick, slow Patrick FIAT Boo Archives 3 13-10-2002 18:11
