![]() | #1 | ||
Posts: 27 Thanks: 2 Trader Rating: 0 ![]() | Metal cover from air con compressor pulley fell off Hello friends, I have a 2011 Fiat Punto Evo 1.4 8V. Last night, the metal piece covering the air con compressor pulley fell off when I started the engine. I managed to fit it by turning it back onto the pulley. Everything was well until this afternoon, when it fell off again when I was moving off from the lights. Had to stop to pick it up from the road. I need some advice on this. Will there be any issues if I were to continue driving without this cover? Alternatively, I can coat the screw threads with 2 part epoxy and turn it back onto the pulley so that it stays there permanently for good? Which will be a better option? Air con compressor seems to be turning and functioning without the cover. The vents are blowing cold air as good as ever. The air con compressor doesn't require replacement yet. Thank you.
![]() | #2 | ||
Posts: 26,377 Thanks: 1014 Trader Rating: 0 ![]() | Re: Metal cover from air con compressor pulley fell off Hello friends, I have a 2011 Fiat Punto Evo 1.4 8V. Last night, the metal piece covering the air con compressor pulley fell off when I started the engine. I managed to fit it by turning it back onto the pulley. Everything was well until this afternoon, when it fell off again when I was moving off from the lights. Had to stop to pick it up from the road. I need some advice on this. Will there be any issues if I were to continue driving without this cover? Alternatively, I can coat the screw threads with 2 part epoxy and turn it back onto the pulley so that it stays there permanently for good? Which will be a better option? Air con compressor seems to be turning and functioning without the cover. The vents are blowing cold air as good as ever. The air con compressor doesn't require replacement yet. Thank you. or just pushes into place.., it it's a thread , I'd use loctite/ maybe even superglue.. on the thread
![]() | #3 |
![]() | Re: Metal cover from air con compressor pulley fell off Don't use glue. Use thread lock or a smear of gloss or car touch up paint this will hold it in place BUT allow removal if needed |
![]() | #4 | ||
Posts: 27 Thanks: 2 Trader Rating: 0 ![]() | Re: Metal cover from air con compressor pulley fell off
![]() | safc biker | Bravo | 4 | 27-11-2015 23:37 |
![]() | zigleon | Punto (Mk2/2b) | 32 | 08-01-2015 20:17 |
Marea Air-con compressor | perom | Auction Watch | 0 | 03-11-2010 16:36 |
![]() | punto60_s | Stilo | 22 | 09-06-2010 14:05 |
Air-con compressor | Gurjit | FIAT Boo Archives | 3 | 30-05-2007 14:47 |
