im Axle Specialists
Old 09-12-2013   #1
Rattle from the Gear Lever
Wonder if someone can help, When I am travelling at high speed (over 60) the gear lever starts to rattle. If I put my hand on the gear lever it will then stop, so dont think its something to bad (loose washer maybe?) but its one of those thats a really annoying sound. I have moved everything out of the car to try and see if it was this, but it was still there. Would anyone have any ideas what it could be.
The car is a Punto My Life 2011 plate.
IOWFox86 is offline Reply With Quote Quote
Old 10-12-2013   #2
Switzerland
Re: Rattle from the Gear Lever
Hello,
It is only your gear lever or you feel vibration in your steering wheel too ?
Punto 2012 Easy - 1.4 8V 77CV - Blue
Mkala is offline Reply With Quote Quote
Old 11-12-2013   #3
Just the gear lever. everything else is fine.
Old 11-12-2013   #4
Switzerland
In this case sorry, no idea...
If you feel vibrations in your steering it can be the wheels balancing...
At which RPM are you at 60 when it make noise ? If you put the forth gear and travel at the same RPM du you have the same problem ? To see if it is generated by engine or relative to car speed.
(T) gear lever fender kev Cinquecento / Seicento 1 23-06-2012 01:26
(T) 1.9 jtd Gear lever Heavy / hard to select gear boldy33 Punto (Mk2/2b) 2 27-05-2011 12:32
(G) gear lever dmrtim Panda (Classic) 4 27-11-2005 19:00
(T) Gear lever helicopter_red Cinquecento / Seicento 2 02-06-2004 06:00
