Mighty_Kri
Just bought and installed clear side repeaters(the small ones). tested the one on the passenger side and it works fine. Tried the driver side and it also works fine(flashes faster as does the rear indicator) but it has blown the bulb in the front drivers side indicator.
I heard the bulb blow when i turned the ignition on to power.
Any advice would be welcome as i will be going to Hellfrauds dinnertime to get a new bulb which i will probably blow again.:bang:
Is this wiring or bulb problem.
The front indicators are also new (clear)
