Backstrum19
- Joined
- Sep 24, 2019
- Messages
- 6
- Points
- 2
I just purchased a new battery and I am having a problem with my steering wheel not locking and the key will not come out of the ignition. I have already used the red emergency release tab on the ignition to turn it to the stop position to get the key out of the ignition, however the steering wheel still wont lock. When I put the key back in the ignition, I hear the fuel pump, I have plenty of lights, I turn the key to start and nothing. The key is now locked into the ignition cylinder again. Only way to remove is red emergency tab. Did I mention that the vehicle will not go into any gear, stuck in the park position, unless, I use the key in the port hole on the passenger side to release the shifter into other gears. Do you think its ignition key related? Why wont the steering wheel lock? Why is my key Stuck?....Please help
