Technical Water Pump
Spotstilo
Which Water Pump 1.4 T jet120?
1.4 Tjet120
My water pump has started to make a clicking sound, so it's going to have to be replaced. It's only been on there for a year (replaced with timing belt just before I bought car), but it's always been a bit noisy/whirring. My usual mechanic said to leave it until it gets annoying: that time has come.
Any suggestions as to which one I should get?
Thanks.
Stick with original. You can get the timing kit with pump from shop4parts for cheap.
Thanks.
Yes, the mechanic said that the water pump was probably not a good one, so that's why it's been noisy. Timing belt looks solid, so it'll just be the water pump being replaced. I'll get the Buggati from shop4.
For the sake of a £30 belt I would do the timing belts again as they will need timing up again anyway once the water pumps replaced. Labour already paid for and peace of mind till its next due.
Even if a water pump was cheap they shouldn't be noisy and just sounds like you got a dud.
