Technical Cigarette lighter fuse..
randhawa
Dear friends,
Could anyone help me please to locate the car cigarette lighter fuse amp in my fiat punto 2000....as my cig lighter is not working.....there is a box near battery, I have opened that ...and there are too many fuses,,,,Not sure which one is for cig lighter...and also don't know what amp is it....:)
Hi, thanks a lot for your help....I don't have 20 a or 44 in the box,,,,,I am attaching pic with this...could you please identify.....:confused:
Hi Mate,,,Thanks again,,,,i have taken that fuse out,just want to confirm it it is the right one,,I am attaching pic...Could you please let me know where i can get it if it is right ...cheers
*facepalm* that picture for demostration purposes on which fusebox you need not the fuse i put the fuse you need posts above f44 20a, put that one you took out back in....
What you removed there is the Headlight Relay
A Relay is an electrical switch that uses a Low current circuit to activate a high current circuit
The Fuse is!
On the very bottom right is a 7.5A (thats your reverse light fuse), the cigar fuse is the one above that
A yellow 20A fuse :)
Ziggy
