DemonPandaOwner
- Jul 24, 2021
- 3
- 1
Hello all. I'm new here and very untechnical so please bear with me.
I have an intermittent issue with my 2004 Dynamic that is quite troubling. The clutch was replaced mid-2019 and ever since when I've been driving for a while the clutch pedal gets squeaky when you depress it. Okay I thought, it's just because it's new and bedding itself in.
Then a couple of times the clutch pedal would stick to the floor and only a good deal of stamping on and swearing at it would get it to release again. It would go away for a while then come back at random.
However, it's now happened 4 times over the past three months and I'm getting scared to drive the car. Usually, it's when the engine is warm and I've been driving for a while. I'm scared that, either someone is going to rear-end me, or the car is going to suddenly lurch forward and cause an accident. I put the handbrake on and put it in neutral but if I'm stuck at lights or a roundabout I'm terrified I'll cause an accident.
So, what I'm asking is, does anyone know what might be causing this? I've read other threads that say it MIGHT be the slave cylinder, etc but nothing conclusive. Neither my local garage nor Kwik Fit who did the clutch seem to know what to do either because it's an intermittent problem. I need the car to get to work, etc but as I said, I'm getting too scared to drive it more than a few miles.
Is it likely that not having driven it much during lockdown last year has caused the problem? Dad had to replace the rear brakes and handbrake adjuster for the MOT in July, and I'm wondering if that has affected things. Having also tried to fix a troublesome misfire I'm ready to get rid of the car but as yet haven't found anything to replace it I can afford.
Can anyone help, please?
