StevePandaCross4x4
- Jul 19, 2021
- 3
- 1
Hi all,
New member. Thanks for adding me.
I have a 2010 Panda 4x4 Cross 1.3 Multijet that has started to intermittently vibrate, usually changing down from 3rd to 2nd, or going downhill.
Once it starts to vibrate, it gets worse and continues even driving on the flat. It seems to stop at faster road speeds/revs, but it might just become harder to detect.
You can feel it through the steering wheel and it is audible inside the car. It gets so bad that you feel sure it must be audible to pedestrians!
It is not a rattle, or a thud, definitely a vibration.
It sounds as though it is coming from below the front seats, or near to the gear lever. It is present even if the car is coasting downhill with the clutch down in neutral.
Not present with the engine running and the car standing still. Not associated with the engine, my suspicion is that it is in the powertrain, but after the engine. Or maybe in the suspension and wheels. Not changed by steering, or front lock position. Vibration increases and decreases with road speed, not revs.
I think that I have ruled out wheel balancing (will double-check again).
I suspected the centre prop shaft bearing (some play when waggled and the bushes looked cracked and old).
So, I got my mechanic to look and he agreed that the prop shaft seemed a likely candidate. Now, we have replaced both the bearing and the prop shaft and it is STILL vibrating.
I am trying to think of other possible causes:
Transfer box (viscous coupling)?
If I disconnect the prop shaft will I be able to check if the car still vibrates in 2WD?
Could it be the engine mounts?
Any other suggestions, or known similar issues with this model?
Many thanks
Here is a v. short vid of it happening with audio: photos[dot]app[dot]goo[dot]gl[forward slash]qWYPBhYo45VE4yXs6
Many thanks
