FIAT Auto Specialist Team
Old 21-01-2021   #1
Israel
Rear indicator light problem
Hi all,
I have the same problem ,panda 2011, as in the video; mine is only at the right side, without the top break light, i.e. when I turn my right indicator light the right indicator works very weak and the break light operates like indicator light.
Im looking for temporal fix till I find a replacement conne (mine is burnt at the black wire), and I was wondering if the fix suggested in the video is fine as a temporal fix
The video:
https://youtu.be/vmvPF9qlZNI
Thanks in advanced,
Gal
"Fiat Lux"
Gala is offline Reply With Quote Quote
Old 21-01-2021   #2
Re: Rear indicator light problem
its rare I have to replace
I normally clean them up and bend them back into shape with a dentist tool
both are normally permanent
koalar is offline Reply With Quote Quote
Old 21-01-2021   #3
Israel
I tried to clean and bend but it got me to the same place... That is the reasone I looked at the video, but Im not sure if its a safe (relatively speaking) fix.
"Fiat Lux"
Old 21-01-2021   #4
done properly and carefully
soldered and heat-shrink
they last for ever and safe
been here a few times both the rear and headlight connectors. Never been a problem again.
Old 21-01-2021   #5
Israel
Im sorry that I nag, but Im not sure I understand your method of fixing... I have zero experience with soldering. I tought about putting extra metal (like spikers wire) in between the gap created by the burn.
"Fiat Lux"
Old 21-01-2021   #6
never tried it.
for me its easy enough to splice on a new connector
having little loose conductive strands of metal floating around would concern me slightly
I would class it more as a temporary get me home type of fix.
Old 22-01-2021   #7
Israel
Update:
I open ir again, but this time I bent the metal pieces that inside the connector, where the black wire goe, toward mebut from the side that near the black wire and not from the side that near the lip of the connector. Bent till all of the 5 metal pieces are balanced. Worked perfect!
Thanks koalar thanked for this post
Likes varesecrazy, SPORTPACK50 liked this post
"Fiat Lux"
(T) help please!!!! brake light + indicator problem!! elky007 Grande Punto 13 28-02-2018 15:22
(G) brake/indicator light problem neil klassen Scudo 3 07-06-2015 22:34
(T) Indicator light problem Holeshot 500 (Classic) 2 19-01-2014 20:03
(G) Indicator light problem in dashboard kaifi Punto (Mk2/2b) 9 26-07-2012 13:08
HELP!!!....indicator/brake light problem!!!! spencer FIAT Boo Archives 5 19-02-2004 09:56
