Ricardogalpini
- Jun 27, 2020
- 54
- 8
It only failed the first fast idle and passes the 2nd fast idle as you can see first fast idle is only just failing then once warmed up a bit more it passes 2nd
you done the same as me
the fast idle has also failed just doesn't have a circle around it
lambda is Bob on. mixture is correct. So CAT isn't doing its job. Clogged or not hot enough
Everything you have posted
Points too excessive fuel is going into cylinders at idle, so much the ecu has reduced the amount of fuel to the lowest limit programmed and the o2 sensor is still reporting fuel rich mixture( 0.9v )
Can you remove the fuel rail with the injectors still attached and the fuel feed pipe still attached?
Does the car have a fuel pressure regulator attached to the fuel rail? Or is the fuel pressure regulator part of the fuel pump?
The mot emission lambda number is a calculation done by the test machine and is at tailpipe so after the cat.yes there loads. But its not what happening here. I thought you only had a problem at idle. Just Google idle, throttle position sensor, mot and emissions. But to me is a red herring as its also failed at fast idle and the lambda is bang on where it should be.
So you have the correct fuel to air but still High CO but HC are okay. The normal "fix" is to get the CAT red hot before the test.
The exhaust calculated lambda cannot be used to say mixture is correct.you done the same as me
It is correct at fast idle though at the very limit that the ecu can reduce mixture.
The mixture at idle is far too rich , high co at tail pipe after the cat proves case(even without a cat if engine was able to enter closed loop and control fuel mixture the co could not reach 8%)
At idle the ops o2 sensor is pegged at 0.9vDo you have an IR thermometer? The catalyst burns excess HCs. The outlet should be hotter than the inlet. If it's the same, the cat isn't working.
Wikipedia says -
Damage
Catalyst poisoning occurs when the catalytic converter is exposed to exhaust containing substances that coat the working surfaces, so that they cannot contact and react with the exhaust. The most notable contaminant is lead, so vehicles equipped with catalytic converters can run only on unleaded fuel. Other common catalyst poisons include sulfur, manganese (originating primarily from the gasoline additive MMT), and silicon, which can enter the exhaust stream if the engine has a leak that allows coolant into the combustion chamber. Phosphorus is another catalyst contaminant. Although phosphorus is no longer used in gasoline, it (and zinc, another low-level catalyst contaminant) was until recently widely used in engine oil antiwear additives such as zinc dithiophosphate (ZDDP). Beginning in 2004, a limit of phosphorus concentration in engine oils was adopted in the API SM and ILSAC GF-4 specifications.
Depending on the contaminant, catalyst poisoning can sometimes be reversed by running the engine under a very heavy load for an extended period of time. The increased exhaust temperature can sometimes vaporize or sublime the contaminant, removing it from the catalytic surface. However, removal of lead deposits in this manner is usually not possible because of lead's high boiling point.
Any condition that causes abnormally high levels of unburned hydrocarbons—raw or partially burnt fuel—to reach the converter will tend to significantly elevate its temperature, bringing the risk of a meltdown of the substrate and resultant catalytic deactivation and severe exhaust restriction. Usually the upstream components of the exhaust system (manifold/header assembly and associated clamps susceptible to rust/corrosion and/or fatigue e.g. the exhaust manifold splintering after repeated heat cycling), ignition system e.g. coil packs and/or primary ignition components (e.g. distributor cap, wires, ignition coil and spark plugs) and/or damaged fuel system components (fuel injectors, fuel pressure regulator, and associated sensors) - since 2006 ethanol has been used frequently with fuel blends where fuel system components which are not ethanol compatible can damage a catalytic converter - this also includes using a thicker oil viscosity not recommended by the manufacturer (especially with ZDDP content - this includes "high mileage" blends regardless if its conventional or synthetic oil), oil and/or coolant leaks (e.g. blown head gasket inclusive of engine overheating). Vehicles equipped with OBD-II diagnostic systems are designed to alert the driver to a misfire condition by means of illuminating the "check engine" light on the dashboard, or flashing it if the current misfire conditions are severe enough to potentially damage the catalytic converter.
Your suggestion would not fix the underlying issue of excess fueling at idle.I don't know about 8%
see post above 5% needed no new parts fitted
HC aren't High.
I would talk to a local garage and get them to do an emissions test for me straight after a proper run.
Unfortunately that doesn't give any useful information.At work so can't do much today, but forgot to mention that when I remove the MAF air/pressure temp sensor and put my finger over the hole the 02 emissions halve to 4 hence why I changed the sensor.
Yes it would have that effectI do get eng man light when I do this
Too much fuel is going in cylinders even though the ecu has reduced the fuel as low as it can, extra fuel is still going in.My mate is bringing me a spark plugs socket that should fit tomorrow, so will take out plugs and post pictures. I have also ordered a 2nd hand throttle body.
1st plug out, looks good
