Hi,im new here
I installed the support, I just need information on where to connect the cables to the body computer.?
My panda is in 2007 year and have 1.1 motor.
Thx
A new or repaired EPS steering column has to be calibrated with suitable software. Multi ECU Scan has the functions to do the job. You need an OBD2 adapter which plugs into the standard OBD port located on the fuse box under and to the side of the steering column. Plug that in, connect your windows laptop and do what is necessary.
That's how I read it too Dave.
If that's the case he'll need the green cable and the registered version of MES.
I was very carefull with my install and have driven about 6 months without calibrating because my cables didn't arrive in time. So I tried it and my Panda drove very well. I did need to connect MES after a long while and recallibrated at that time. The difference was almost unnoticable.
