FIAT Auto Specialist Team
Old 23-08-2019   #1
Coolant level question.
I don't want to hijack an earlier thread about cooling system so i will start my own.
I have a 2009 1.1 active eco. I have had an airlock in the system for some time, heater on and off, sometimes its hot other times cool, i set about fixing this and bled the system using the screw near the heater hose, this has fixed it, heater hot now, the coolant system holds pressure for days when cold (car not used) if i unscrew the header tank cap i can hear the pressure hiss out (no leaks) question is this, i fill the tank to max, then go for a run, when i shine a torch to check level, it is below minimum, if i undo the cap, the water level rises to where it was when i filled it, is this how it should work? ie, is this ok.
Stavros2 is offline Reply With Quote Quote
Old 23-08-2019   #2
Re: Coolant level question.
Yes.
Likes The Panda Nut liked this post
jimboy is offline Reply With Quote Quote
Old 23-08-2019   #3
varesecrazy has donated!
Its a pressurised system.. so it looks like the cap is doing its job
IF the reservoir was easier to see..
You would see the level drop away as the cooling fan cuts in..
Charlie
Old 23-08-2019   #4
You still have air or gas in the system. As it compresses the level goes down. As it expands when the cap is removed the level goes up. Needs sorting ASAP
koalar is offline Reply With Quote Quote
Old 23-08-2019   #5
There's two bleed screws the other is at the top of the radiator left hand side if you are facing the car. This should be done first. Undo when cold then top up until some liquid starts to exit the hole.
Old 23-08-2019   #6
When pressurized the level shouldn't go to minimum. When hot the level should rise slightly
Old 24-08-2019   #7
Quote Originally Posted by koalar View Post
I don't quite understand why you think i have a problem, i seem to have conflicting replies, i would have thought that when the car gets hot, pressure should build up, every car i have owned, if you loosen the rad cap pressure hisses out, my panda does not overheat, does not lose water etc. where should the water level be when the car is hot and cap still in place?
Old 24-08-2019   #8
Coolant level cold should be above the minimum. I set mine between max and min lines. Level goes up when hot as coolant expands.
Paraoxically the hot level is different if you run engine until hot with radiator cap removed. This is because the hoses expand slightly with normal running pressure. However, the fluid expansion causes a much bigger volume difference.
Set level between the lines when cold. Job done.
If the coolant tank is too dirty, use a wood dowel as a dip stick to check fluid level.
DaveMcT is offline Reply With Quote Quote
Old 24-08-2019   #9
Smile Re: Coolant level question.
Quote Originally Posted by Stavros2 View Post
shouldn't do this unless there is air/gas in the system
Old 24-08-2019   #10
OK, i have just been to the car, i have filled the rad tank to the max mark, then run the engine till the temperature midway, i checked both bleed screws, the one near the heater matrix still had air in it, so i bled it, stopped the engine, water level was just above min, so i topped it up to max, ran the car again, heater mad hot now! far better than it has been, temperature reading normal, no overheat, stopped the engine, shone torch on reservoir, level at max, it seems ok, will not know until i go for a decent run next week, but i am confident i have got all the air out, presumably all this started off when i had cam belt and waterpump done last year.
Thanks for all the help and advice
Thanks koalar thanked for this post
Old 24-08-2019   #11
just keep an close eye on it over the next few weeks.
Old 25-08-2019   #12
Will do, thanks
Old 26-08-2019   #13
Filling it to max when hot means the system will most likely throw out some excess coolant. A lower level after the first drive would be normal as the coolant has found its correct level. It should then remain constant.
(G) Coolant Level LandieMan Punto (Mk2/2b) 4 04-03-2013 20:22
(T) Why can't I see my coolant level?? DynamicPanda Panda 4 28-12-2011 07:59
(T) coolant level question 1.8Stilo Grande Punto 1 11-04-2010 09:42
(T) Coolant level vengod Punto (Mk2/2b) 2 01-12-2008 16:03
(T) Coolant level HornetUK Punto (Mk2/2b) 7 01-05-2005 23:34
