Hi, anyone know who supplys bottom outer sills panels? Or a part sill rear from wheel arch to jacking point. Thanks in advance.. Sorry car panda dynamique 07 reg.
Surprising needed already.
Probably available form your Fiat dealer, at a price.
A leading panels aftermarket supplier in Europe is Van Wezel. Part of Unipart Group (HQ Oxford UK) but unable to find stockists in UK via Google.
Apart form this:https://www.autodoc.co.uk/car-parts/footboard-door-pillar-11792/fiat/panda No idea about this supplier.
The parts you'd need would be 1709103 LH, or 1709104 RH.
If they're Van Wezel, they'll be good.
Hi, portland bill, reason so soon ,recently went in garage for coolant pipe change. they placed pads on four leg lift, placed pads on the end of rear sills not jacking points thus crushed them. big dispute with garage They denied not their fault, never no problems ie rust..
i would find one in a scrap yard cut through the sill with a hacksaw then cold chisel the spot welds with a bodyshop flat chisel
then take the two bits to the garage and get them to weld them in neatly
to be honest ive never had a problem jacking pandas up on the pinch sections
